Old 10-11-2012, 11:56 PM
Larrick Larrick is offline
Mein Auto: 1994 525it
The oil is clean mobil 1 synthetic. But the head gasket can still be bad, right? Will the coolant circulate with a bad water pump as long as the thermostat is open?
Also I have read in many threads that white vapor is quite normal for the m50 engine, is that true?
Is it important to raise the front of the car during bleeding?
Why would only the driver side heat get hot?
