Bimmerfest - BMW Forums - View Single Post - Transmission Warning: Gear in use without Break
Old 10-13-2012, 03:51 AM
kskane's Avatar
kskane kskane is offline
From DownUnder
Mein Auto: '04 525i M54 with 6HP19Z
Originally Posted by bimmerfan52 View Post
If they said Vaseline that is what I would use.
Thanks BimmerFan52.
I took the pan off and had the sleeve ready, but I can't find where does the sleeve goes? With pan off, I can see under the transmission there is absolutely no place where the sleeve is visible. Is it hiding under "sleeve locking mechanism" or do I need to pull the valve body to reach the sleeve? What are the symptoms of leaking sleeve anyway?
Also, my pan was changed about 12,000K's during the transmission oil change. I do have a new pan, but the old one seems to be okay. Do you think I should change the pan, or just the two oil drains as recommended earlier in this post? I have the pan off at the moment as I am trying to figure out the sleeve and have to get 12 new bolts (which I am going to do a washer + M6 high tensile bolt combination).
Would appreciate if anyone can share there thoughts on the sleeve and pan.
