Old 10-13-2012, 05:16 AM
wifesauto wifesauto is offline
Mein Auto: sloporsche
not clear. did you replace fuel pump before or after no start ? check for codes,check for crank shaft /camshaft signals to ecm. disconnect MAF sensor and try. put a noid [tester] on injector plug and look for pulse. it would seem you have spark but no fuel. if this all came about after pump replacement go back over your work and look for something amiss
