Bimmerfest - BMW Forums - View Single Post - 1999 BMW Z3 Crank but no start !!!
Old 10-13-2012, 08:28 AM
munibmw munibmw is offline
Mein Auto: 1996 BMW 328ic
Originally Posted by brock5ga View Post
If it tries to start when sprayed, probably not getting injector pulse. Look at the tach while cranking to see if it moves. If not, probably crankshaft position sensor. May be inexpensive enough to try. If you do not have anything to pull codes and/or monitor data, then recommend taking to shop. Also try the MAF sensor as recommended.
The tachometer does not move while cranking. Does this mean that the crankshaft position sensor is bad? Is there a way to test before replacement?
Another thing I noticed when I first removed the engine covers is that the ignition coil closest to the front of the car was missing a bolt and the other bolt, the one that holds the ground cable was loose and about to fall. Probably not related but, I have replaced the bolts and made sure all the other bolts and ignition coils are secure and working.
