Old 10-15-2012, 05:44 PM
kskane's Avatar
kskane kskane is offline
From DownUnder
Mein Auto: '04 525i M54 with 6HP19Z
Originally Posted by HPIA4v2 View Post
Sounds like you have no leak on your mechatronic sleeve, since you have 5.5 quart/litre on fluid when you dropped the pan. I'll say just replace the filter and re-fill with fresh fluid and you are good to go. BTW always use ZF filter and fluid, just to make sure you have no compatibility issue down the road. Not sure where to get those in down-under.
Found a good deal on ZF liquid gold and will be using that. Do you think it was under filled since only 5.5L came out?
