Old 10-16-2012, 06:55 PM
lakeeriesailor lakeeriesailor is offline
Mein Auto: '03 bmw z4 roadster
Z4 Soft Top Removal and Motor Replacement Procedures
Hi, Gene
Thanks for the response. I'm still a bit unclear about the use of the bent screwdriver; did you mean that you used it to replace the convertible top or the "top" that fits in the trunk to mask the trunk's contents from outside view? If you're talking about the convertible top, then how did you replace the plastic clips that hold the trunk "top" in place?
When I put the "hoop" back into place, I did start at the center, but didn't tap the "hoop" back into place. I wonder if that's my problem with the boot on the passenger side not fitting properly?
