Bimmerfest - BMW Forums - View Single Post - Car Won't start immediately anymore
Old 10-17-2012, 03:49 AM
jwrape jwrape is offline
Mein Auto: 96 Z3M (M S52 conversion)
Originally Posted by BMWFatherFigure View Post
So did you get the injectors cleaned and flow tested? How fast does the fuel rail loose pressure?
Almost immediately falls to a little over 20psi, but in the same when the car turns over it jumps back up to over 40psi. No I haven't had then cleaned. Prolly wouldn't be a bad idea. I have another set of injectors as well if I needed them.
But it runs good once it's started, runs normal and strog.
