10-17-2012, 06:15 AM
Mein Auto: 07' 550i
It has ARS system, and all sport pckg, (car sits low, different size tires for front and rear ), I guess I will list below.
CodeDescriptionCodeDescription
0ZCW Cold Weather Package 0ZPS Premium Sound Package
0ZSP Sport Package 0205 STEPTRONIC automatic trans.
02VB Tire pressure monitor 0319 Universal garage-door opener
0322 Comfort Access keyless entry 0403 Moonroof
0415 Power rear sunshade 0416 Rear sunshades
0430 Auto-dimming mirrors 0431 Auto-dimming rearview mirror
0441 Smoker's package 0508 Park Distance Control
0522 Xenon headlights 0524 Adaptive light control
0609 Navigation system 0620 Voice-command
0639 BMW Assist w/Bluetooth System 0655 Satellite radio w/1 year sub.
0697 DVD Area coding, North America 0818 Battery switch
08SP CO2 control 0925 Shipping package
09AA Transport protection 0ZFA First aid kit
0ZFM Floor mats 0ZIA Anthracite Maple wood trim
And some repair history from owner 1
Center
IDLoc
IDClaim
NumberRepair
Order
NumberRepair
Order
DateRepair
Entry
DateDAVIS
#MileageDefect Code/Description
232760138592023429406/07/201106/08/2011669,7810034910100Ck Brake Booster line N62, B34 04 10
232760138591023429406/07/201106/08/2011069,78111720376MPENG AIR FILTER-DIRTY-MP
34117777MPFRONT BRAKE PADS & ROTORS - MAINTENANCE PLAN
61610077MPFT WIPER RUBBER INSERT-MP
85990091MPOIL SERVICE(MP)AFTER THE 1ST
85990501MPSTANDARD OPERATION MP
232760119383920422505/04/201005/05/2010059,12499999977ESEXTENDED SERVICE DEDUCTIBLE $50.00 PER REPAIR VISIT
232760119383020422505/04/201005/05/2010059,12434000077MPBRAKE FLUID CHANGE- FULL MAINTENANCE PROGRAM
64310237MPMICROFILTER REPLACEMENT
72110780ESUNKNOWN
23276018356018576308/27/200908/27/2009054,01685990091MPOIL SERVICE(MP)AFTER THE 1ST
23276012577017706905/05/200905/07/2009449,3762400339800Positive engagement, delayed, automatic transmission not satisfactory
2400514800Leak at gearbox connector, automatic transmission leaking
232760192444016192710/15/200810/17/2008240,3293421193900Rear brake pad wear sensor unpleasant noises
232760188826015606807/30/200807/31/2008236,6583411043900Front brake pad wear sensor unpleasant noises
85990101MPVEHICLE CHECK
232760183470014749804/08/200804/09/2008031,13164310237MPMICROFILTER REPLACEMENT
232760180263014225401/28/200801/29/2008227,2930012510200SIB #12-10-07 LBL 510 GROUND STRAP RETROFIT ON E60,E63,E64,E70 WITH N62TU PROD 3/22/05 TO 6/27/07
232760180262014225401/28/200801/29/2008027,29311720376MPENG AIR FILTER-DIRTY-MP
220060191814026537104/11/200704/20/2007213,1606510199800Audio output, radio / ASK / MASK / CCC not satisfactory
22006019188706500204/10/200704/21/2007113,1480061510200SIB #34-05-06 LBL 477 CHECK SZL OPTICAL ELEMENT ON E60/61/63/64 PROD FROM 8/26/05 TO 7/28/06
220060191698026500204/09/200704/18/2007313,1480033590100SIB #33-02-06 LBL 471 RECALL 06V-277 INSPECT REAR SHOCKS E60
220060191697026500204/09/200704/18/2007313,1481011004700Cold start drop in engine speed
5186200100Rear seat cushion covering, cloth cracked / broken / torn off
85990089MP1ST ENG OIL SERVICE-FULL MAINTENANCE
BMW CCA Member, Capital Chapter
