x3 on a leaky VCG (assuming the dark portions on the heat shield aren't underexposed areas of the picture). I'd recommend getting a replacement valve cover (includes perimeter and spark plug gasket) as well as the 15 sealing grommets for the bolts. Chances are you'll crack your existing valve cover if you replace just the gasket.
----Brian
