Bimmerfest - BMW Forums - View Single Post - Oil coming out of rear O2 sensor
Old 10-18-2012, 05:31 PM
ahull's Avatar
ahull ahull is offline
Originally Posted by gesoffen View Post
x3 on a leaky VCG (assuming the dark portions on the heat shield aren't underexposed areas of the picture). I'd recommend getting a replacement valve cover (includes perimeter and spark plug gasket) as well as the 15 sealing grommets for the bolts. Chances are you'll crack your existing valve cover if you replace just the gasket.
Why would the vc crack when replacing the gasket? I would think chances are it won't crack unless you're just careless or don't properly torque the bolts.
