Bimmerfest - BMW Forums - View Single Post - Stupid HVAC prb has everyone stumped
Old 10-18-2012, 10:17 PM
tranquility tranquility is offline
Sportscars only.
Mein Auto: 2011 Z4 sDrive 35i
'Tranquility Fix'
Ok, guys, I may have stumbled upon a possible solution. You know how presumably everyone starts the car by pressing the brake, and then pressing the start/stop button? I've been doing it the other way around, i.e. holding the start/stop button and pressing the brake to start the car. So far, no more HVAC prbs (knock on wood). Pls note that if you do it the 'normal' way and the HVAC malfunctions, you can't try to restart it using my way afterwards as the HVAC needs time to recover (as per usual whenever it malfunctions).
I'll leave it up to you guys to field-test this to see if my solution actually does work. Just call it the 'Tranquility Fix' if this does work.
