Old 10-19-2012, 12:12 AM
Yorgi's Avatar
Yorgi Yorgi is offline
Originally Posted by slemmer View Post
Ok, I did the repair. Weird that the replacement cap didn't have a vacuum hose nib attached to it but the older one has the nib molded to the cap. Does anyone know the part number of the add on vacuum hose nib? Thanks. Stephen.
From the DIY above:
>> IMPORTANT, if your CCV kit does not have the vacuum hose attachment be very carful in removing the tabs as you will need to re use the cap. Refer to picture 6.
I believe that extra vacuum line goes to the fuel pressure regulator. On newer cars this line has been eliminated but you need to attach it to the CCV if your car has that extra line.
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
