10-20-2012, 05:19 AM
Mein Auto: 2011 535i M-Sport
Originally Posted by mateforrest
Thanks Shawn we did it
Also i tried to use this code:
HI_CIC - 3000 HMI - ECO_MODE = aktiv (Displays Efficient Dynamic Menu in CIC Nav menu)
KOMBI - 3003 FZG - VERBER_HISTOIRE_ENABLE = aktiv (Enables fuel consumption histogram)
KOMBI - 3004 ERM - CTR_HSTY_DISP_KI_APPL = aktiv (Enables fuel consumption histogram)
But only the CIC fuel Consumption in the CIC Nav menu is working, the rest exist but is dummy.
I think as you said in another post that is better : add option 4U2 to your VO and write it to the car. Then you would VO Code KOMBI, HU_CIC, JBBF, and IHKA.
But i´m not sure how to change production data.
Regards
Read this as an example for how to change FA (VO) to add 4U2:
https://www.rapidshare.com/files/322...ries%20car.pdf
QUIT AFTER STEP 7. You do not need to, and should not, write this FA to the car. Just use it for VO Coding, but let the car store the original FA.
What it does not explain is how to also change your FA Production date. For that, you need to change the FA Zeitkriterium field. You can only use dates that coincide with an actual Integration Levels (e.g. 0311, 0711, 0911, 1211, 0312, 0712).
I am using 0712. If your car was built before 0312, and you use a >= 0312 Production Date, your Oil Level Measurement Screen will change an no longer work. To return it back to the original style, FDL Code OELSTAND_OENS = nicht_aktiv after VO Coding it.
Make sure you read both of these posts first:
http://www.bimmerfest.com/forums/sho...d.php?t=642231
http://www.bimmerfest.com/forums/sho...d.php?t=647622
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11)
- BMWCCA #446923
- flickr®
