Bimmerfest - BMW Forums - View Single Post - Brake Pad and Rotor - OEM Brand
Old 10-22-2012, 01:19 AM
jackMA jackMA is offline
Mein Auto: '06 525Xi
I have not used the Ferodo pads. Chances are, if the pads are a ceramic material, there will be less dust on your rims.
I replaced the fronts and rear pads with Hawk HPS pads recently. What use to be a weekly cleaning of the rims with original pads is now a once a month cleaning with the HPS pads. I like the HPS pads braking performance, a slight increase over the OEM pads, but I find that I have to apply more pedal pressure to hold the car when its stopped. For me, that's a reasonable trade off.
Before replacing the pads, check your rotor thickness with a micrometer. You'll need a 1"-2" range for the fronts. I think the minimum thickness is 28.4 mm (1.118") but you should check that. The OEM rims wear quickly. Mine were toast at about 70k miles.
