Old 10-23-2012, 06:10 AM
SuperSnoop's Avatar
SuperSnoop SuperSnoop is offline
Mein Auto: 2007 760Li
Originally Posted by mortyx10 View Post
correct...you can only add parameters (which is simply possible by nettodat coding, no disassembly required) if the function is already defined. in this case we define it first in our SWTFSW02.dat and your right we can name it whatever, the keyword 1500 is more important. it must be unique.
I already have a function defined as 1500. I assume I should just take the next available spot (1528 in my case), and then change all references to 1500 in all three files?
My rear DVD player isn't working at the moment, so I won't be able to test it right away, but this seems pretty simple.
