10-24-2012, 06:05 PM
Mein Auto: 2009 E93 N54
Originally Posted by TXFred
1. Do the FSDs provide any way to adjust ride height? I'm not looking to lower the car, just adjust it to factory specifications. Possibly, I'd even raise it just a bit to get some more clearance on speed bumps.
2. Does the car need to be aligned after I replace the struts, assuming no other changes are made?
3. Does the car need to be aligned after I adjust the ride height?
1) No
2) Recommended
3) Yes!
I wouldn't raise the height. Skosh lower maybe, but there's no stock adj. Stock alignment: Front & Rear Toe; Rear Camber. Zero thrust angle. Optional: BMW recommended weights.
Here's what I did - might assist.
