Bimmerfest - BMW Forums - View Single Post - FSD's, ride height and alignment.
Old 10-24-2012, 08:21 PM
TXFred TXFred is offline
Mein Auto: 2008 335i Convertible
Originally Posted by CALWATERBOY View Post
Here's what I did - might assist.
Good link. Thanks!
Since I'm just swapping struts, I assume I won't have to do as much work as you did. Reading your post, it's hard to tell what is part of the strut replacement, and what is being done so you can add /M components.
I've done shock replacement before (Nissan pickup) but not struts. With shocks, I just jack the car, remove the wheel, unbolt the shock, then install the new one. With the struts, is it the same other than the need to use a spring compressor?
Frederic
