10-25-2012, 06:27 AM
Supporting Vendor
Mein Auto: E63 650i
DIY - Oil Change with Pics
Hi Guys
Just did the oil change for the first time on my 650i
Here are some steps
BMW N62 Oil Change
This was performed on a 2008 650i, but as the title indicates, its good for all the N62 engines.
Tools needed (besides the obvious oil catch pan, ramps, oil and oil filter.)
1st = 8mm (Plastic cover), 2nd = 8mm (Main drain plug), 3rd = T40 (Oil filter drain plug), 4th = 24mm (Oil filter housing)
After the car is jacked up, you will find this plastic cover, remove this cover.
Remove oil drain plug. (remember to put the catch pan below!)
Drain the oil from the oil drain plug.
Change the oring on the oil drain plug.
After draining the oil filter housing, remove the oil filter housing.
Picture of the new and old oil filter.
Change out the oil filter housing oring.
assemble everything back and make sure there are no leaks. Fill up with the new oil and you are all good to go! And you just saved about $100 vs. bring it to the dealer.
| Bimmerzone.com | 1-800-357-7797 | info@bimmerzone.com | 833 Lincoln Ave, Suite 5, West Chester PA 19380 |
Video about Bimmerzone: http://www.youtube.com/watch?v=me5pjPS88Bw
We are proud to be Authorized Dealers for: Sprint Booster, Peake Research, Eisenmann Exhaust, Hartge, RPI Exhaust, AutoEnginuity, Bentley Publishers, Zymol, P21S, PowerFlex USA, Brembo GT, KW, Hawk and much more!!
