Bimmerfest - BMW Forums - View Single Post - An Intricate Misfire.
Old 10-25-2012, 03:53 PM
Hemorrhage Hemorrhage is offline
Mein Auto: BMW 335xi
Originally Posted by Orient330iNYC View Post
have the intake valves been cleaned?
Not that I know of.
Why would they need to be?
@TXFred I played that little swap game 500 times (refer to the link I posted).
The misfire has no pattern.
Originally Posted by Braumin View Post
Misfires under load like this are almost always the secondary ignition. My first guess would be a bad spark plug, and is the cheapest to test out.
If you change your plugs and are still having the issue, you can try swapping the coil on #6 with the one on #1 and see if the misfire moves to #1.
I have new plugs in it. NGK Platinums or something. The car has 71.5k miles on it now. I believe I put the plugs in at 69k.
