Bimmerfest - BMW Forums - View Single Post - An Intricate Misfire.
Old 10-25-2012, 06:05 PM
DSXMachina's Avatar
Bimmerdex 7.4!
Originally Posted by Hemorrhage View Post
After taking the JB4 out of my car (this is assuming you read the thread I linked), I bought a Bavarian Tech cable. My car was kind of running like **** even with the JB4 out, so I eventually just checked every code that was stored.
I had codes coming out of every orifice...
Codes from the transfer case.
The transmission.
The engine.
Etc.
Thinking it would be like all of the other times (where I would just delete the misfire code and the car would run like normal), I just deleted them. The car ran like normal after that.
I bring this up, because maybe those codes play a roll in what's happening now.
I did take a picture of each code before I deleted them. However, those are on my old phone, which doesn't have a charger.
However, ever since then, the only code I've gotten was a cyl6 misfire.
I want to take it to BMW. But, I can't go without a car.
You had all those codes because your voltage dropped below about 10 volts at some point. That'll light up everything including the ABS/DTC/DSC Christmas tree.
You will be going without a car soon, one way or another.
