Old 10-25-2012, 07:27 PM
Banned
Mein Auto: car
Originally Posted by 1995i540 View Post
Carsoft is garbage, the setup described above is garbage as well unless you can get your hands on a proper laptop that matches specs to the point.
Otherwise have fun having horrible feedback/unstable setup and reinstalling it every few weeks. Major PITA.
There are many people who use ediabas/inpad, easy dis, gt1 and other similar systems reliably. The key is good preparation, which comes from reliable and comprehensive information, which can only be identified by the determined application of patience to the process of online research.
In short, if you're not a pioneer for something, and you have screwed it up, then its quite likely that you've not done sufficient research to prepare yourself.
The most effective mantra when approaching such situations seems to be "no pressure, no pressure. "
