Thread: aux-in
Old 10-27-2012, 03:37 PM
rebel.ranter rebel.ranter is offline
Mein Auto: 630i, 525i, 320iC
To enable the AUX function in your iDrive menu you need to enable it using coding software.
You can probably use the following software:
- Autologic
- Progman
But I know for certain that you can use NCS Expert.
In NCS Expert you connect to the car & change the setting AUXIN from nicht_aktiv to aktiv in the MASK or CAPPL module depending on what you have in your car. You also need to add +NAUX to the VO (Vehicle Order), the VO is usually stored in the CAS & LMA modules.
There's loads of sites with DIYs for updating the VO & coding modules. The changes above would take 5-10 minutes all in. Progman has a fancier GUI & it might be easier to do but it will take longer.
You then buy a retrofit kit, part number: 65 12 0 153 502
Here's BMW's own guide for performing the retrofit for the e60 & e63/4, it is largely the same, all the hardware in our cars are e60.
http://www.kneb.net/bmw/E60-1/Aux%20Input.pdf
