the racing springs i got for this setup are actually smaller in both length and diameter. hardware modifications had to be done in order to insure fitment. the hats were replaced with custom ones fabricated by my indy. If the springs are bad you should be able to get replacement one from bilstein. too bad your car isn't the same as mine, or i'd sell you the springs that came with the coilovers. If the shocks are leaking you can send them in to get the revalved.
