11-03-2012, 10:13 AM
Mein Auto: E85 M-Roadster, E82 135i
Originally Posted by Bray0671
I put ATF redline and I just figured out the next day. I have 3 quarts coming to do another flush I only flushed 1 1/2 quarts of ATF so I think 3 quarts should be enough for a flush. Do you think this is why the steering lock light is on
If the light came on immediately it may be related, but I would try to replace the fluid and bleed the system by turning the steering wheel twice each way to full lock, then topping up as necessary.
