Old 11-04-2012, 08:40 AM
BenF12400 BenF12400 is offline
Mein Auto: 2006 X3; 2010 528;2013 X5
Check your tire pressures; I found that although I picked up by 2013 X5 3.5 at the "factory, the pressures were way off (you do know to check when cold) so I added air to the recommended pressures for front and back tires and did the reset. My higway mpg is 26-27 on premium, drops to 22 mpg if I have a bad day on the capital beltway. Radio will turn off once you open the door to get out of the vehicle.
