11-06-2012, 06:57 PM
Mein Auto: 2011 528i
Originally Posted by miamiboyca
4 years, 50,000 miles. Period.
Obviously its enough to bug you... take it in and show it to them. Continue to do so until they fix (provided you can continue to reproduce it)
My $.02
The problem is with the OP's winter wheels (aftermarket) and winter tires, so if the OEM wheels/tires are vibration free, this is not BMW's problem.
As far as warranty on the wheels, you need to check with the manufacturer. If one of the wheels is dented/warped, the OP probably is out of luck.
Get the tires Road Force balanced and make sure to get a print out of the balance report.
Also, make sure that the hub rings are installed and not damaged. Plastic ones aren't very durable but do have the advantage that they won't seize to the hubs.
