Bimmerfest - BMW Forums - View Single Post - Temp gauge/ sensor /alarm questions
Old 11-07-2012, 10:25 AM
1995i540's Avatar
1995i540 1995i540 is offline
Founder @ Maintenr
Mein Auto: 1995 540I/6
1. Instrument clusters (temp readings) are slow and I would say not very reliable due to lag.
2. In 540I as I can recall you have a switch sensor and coolant sensor in rear and in radiator. All 3 sensors are exposed to coolant.
3. This is pretty simple, take a coolant sensor and splice the wires, all coolant sensors have Ohm spec that represents temperature state once it reaches certain Ohm you can sound the buzzer. I would avoid doing anything directly with cluster because of lag problems.
///////////////////////////////////////////// E34 Addicts
Founder @ Maintenr. Take control of your vehicle maintenance.
