Originally Posted by mlevack
BMW is still in transition with the navigation systems. The newer systems are installed with US maps, then they use a USB thumb drive for the European Maps while you are in Europe. This does not require map reprogramming. The current / previous navigation is programmed with European Maps and has to be re-programmed. The advantage with the new system is that they do not need to re-program the system, the down side is that the USB drive uses the USB port, so you can't use it for your ipod or phone.
I can't speak for other models but on the 5 that was not an issue as there is more than 1 USB port.
2013 535i Space Grey, Biege, M-SPort, Premium, Tech, Cold Weather, Luxury Seating, PDC, 6MT ED-10/11/2012 - PCD Redelivery-12/14/12
