11-07-2012, 03:22 PM
Mein Auto: 2013 M3, 1993 325is
Originally Posted by mlevack
BMW is still in transition with the navigation systems. The newer systems are installed with US maps, then they use a USB thumb drive for the European Maps while you are in Europe. This does not require map reprogramming. The current / previous navigation is programmed with European Maps and has to be re-programmed. The advantage with the new system is that they do not need to re-program the system, the down side is that the USB drive uses the USB port, so you can't use it for your ipod or phone.
Exactly...CIC systems still have the maps loaded.
Originally Posted by miamiboyca
I can't speak for other models but on the 5 that was not an issue as there is more than 1 USB port.
Yes, but only the center console port takes the maps, and only the center console port can accept an iphone/ipod. You can't use both.
