Old 11-07-2012, 05:54 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Maybe this video will bring a bit of enlightenment as to how the interior shade panel and glass roof panels are designed to operate (shade panel should fully retract):
Here's a link to the online BMW TIS. Since you provided model info...I was able to get you all the way to the TIS documents for the sunroof. You will see the TIS documents available for reading in the far right column. Since 10 SUNROOF is highlighted...you'll see the 5 TIS docs that are available to read. The links are live...and you can also click on the other 2 areas that will also have TIS documents you can read (12 mechanical & 13 electrical sunroof components): http://tis.spaghetticoder.org/e53/X5...e_top/sunroof/
I hope this provides you with the info you seek...good luck and report back if it helps or not.
Q {BMW CCA Member #191509}
(SOLD)
