Bimmerfest - BMW Forums - View Single Post - Moonroof and/or Sun Shield remove and replace
Old 11-09-2012, 12:32 AM
DDutchman DDutchman is offline
Mein Auto: 2005 X5 3.0i
Fantastic, detailed information! Keep it up. In my case, the rear window has not opened since I got the X5. However, one day I was just sitting in the car, hands off, when the front glass opened part way. That is when I learned about the manual crank. I also learned the non-BMW used car dealer had disabled the panorama switch but not the motors. I pulled the power to the front one. While trying to figure what was what I came across a couple of small, translucent white rectangular pieces that appear to be broken off from the rail system that are about 3-4 millimeters. From what else I have learned from the links you provided it looks like one of the sliding visors jumped the track and is jammed over the ventilation grille. The other one is loose and slid all the way back into the headliner. Since the tracks are black I wonder what the white pieces are for. Could they be the guides for the sliding visor?
