11-09-2012, 10:59 AM
Mein Auto: 1999 740i
Your going to have to elaborate more on your story. Im very curious toknow where this story is going. "Tracking device"? Falsely accused?
To answer your question: No you will not get a DSC light if you just pull the brake lines off or on. You will get the light if a wheel speed sensor is bad or abs control mod is bad, or brake fluid low. Now if you pulled the brake lines and didnt bleed them when you put them back on, it is possiable that some air made it up to the abs control mod and caused an error. If you had that much air in the system your brake pedal would feel spongy as hell and your car would not brake worth a $hit.
