Bimmerfest - BMW Forums - View Single Post - Yet another issue - M60
Old 11-10-2012, 02:01 PM
Banned
Mein Auto: car
Originally Posted by snowsled7 View Post
" This article needs attention from an expert in Physics. Please add a reason or a talk parameter to this template to explain the issue with the article. WikiProject Physics or the Physics Portal may be able to help recruit an expert. (August 2009)
This article needs additional citations for verification. Please help improve this article by adding citations to reliable sources. Unsourced material may be challenged and removed. (March 2010) "
The portal I referred to earlier is a physic portal. Here's one from a university's lecture material :
http://www2.le.ac.uk/Members/mr6/lec...s-students.pdf
To quote " The properties of elastomers are remarkable and very different to almost any other solids. For example, ideal rubber does not expand when heated. In fact, loaded rubber will actually contract if heat is applied. "
Applying a layman's "things expand when heated" understanding is quite clearly unsafe when it comes to elastomers, which react differently to changes in entropy from undisordered solids.
rgds,
Roberto
