Old 11-12-2012, 07:01 AM
vintage42's Avatar
vintage42 vintage42 is online now
BMW CCA 1405
Originally Posted by Pinecone View Post
... changing the oil does not 0 the indicator, you have to do that yourself. A quick search will find the two pins in the connector under the hood to short together...
I knew you had to reset the indicator by grounding the 7 pin. Dealer did my oil change. I just meant whoever did it, all the fluids should be changed which would set the car (and the indicator) to a new and known maintenance schedule. JimCameron said he had no maintenance records on his car, and I was in the same situation.
