Bimmerfest - BMW Forums - View Single Post - 645ci Oil Leak help - have pic
Old 11-12-2012, 09:12 AM
Medicus Medicus is offline
Marine
Mein Auto: 2005 BMW 645Ci
Yes i have already replaced the O-ring which solved one leak. Where it is leaking at now is from the very edge of the vacuum pump towards the front of the vehicle. There is a plate on the front of the vacuum pump that you can see it looking at the engine from the outside. it appears that is how they installed all the internals. I was wondering if I can take that outside plate off without anything inside falling apart. There is only four bolts holding it in place so it would be really easy to take off I just don't want the vacuum pump to fall apart when I unbolt that front plate
