Maybe you installed the ccv wrongly. Although the car cant go so badly wrong that way....at most you would have weird idling or economy.
If this only happened after you installed it, then you must have screwed something up. Go through evrrything in your head slowly and doublecheck your work while at the engine.
I wonder....hmmmm.....if you are suddenly losing so much oil, did you somehow insert the ccv tube right into the oil in the oil pan? So its sucking up oil into the chamber and not just oil fumes?
