11-13-2012, 06:16 AM
resU deretsigeR
Mein Auto: Z4 sDrive20i
I drove the Kangoo Z.E. and Fluence Z.E.
Last weekend, I drove both the Kangoo Z.E. and the Fluence Z.E. Missed a chance at a test drive in a pre-production Zoe by a day.
These two cars are products of the Renault – Nissan alliance. They share technology with the Leaf, although the Leaf is a very different car.
Both vehicles have a 22kW-hour lithium-ion battery, an onboard 3.5kW charger, similar power management and a 1st generation Renault 5A electric motor. Output for the Fluence is 70kW(90hp) with 226Nm of torque available almost from a dead start. The Kangoo motor has the same 226Nm of torque but a maximum output of 44kW(60hp).
2nd Generation 5A motor from a Zoe. 1st gen looks very similar. I've seen rumours Kangoo gets the 2nd generation some time next year.
We drove the van first, since we are shopping for a new van. Sitting still, it looks and feels the same as a diesel powered Kangoo. Same seats, same exterior, same payload area, same payload capacity. The dash is a little different. The temperature gauge is replaced with a gauge showing power into or out of the pack. Just below that gauge is a small computer display. A second small display is under the speedometer. That one displays all the usual things, temperature, miles to empty as well as power consumption in kW. A large battery level gauge replaces the tachometer.
Controls are well laid out and easy to use except for the economy mode switch.
Kangoo Z.E. dash.
The RHD van I drove was the same except it was ummm right hand drive, the spedo was in MPH and it didn't have cruse control.
Underway, it is obvious this isn't a diesel. We have driven a lot of small cargo vans recently and they are all noisy. The back of a van is a big tin can that resonates with drive train, suspension and road noise. We can't hear the radio in our Vauxhall. VW's Caddy with their latest diesel is quieter than most, but still noisy.
The Kangoo Z.E. is quieter than most passenger cars. Not only is there almost no engine noise, but there is less noise overall. Renault must have done something to cut down on the little squeaks, creaks, and rattles that plague most vans.
The Kangoo Z.E. is the best riding small van I've driven. The battery pack is below the cargo floor, in between the axels. This puts 250kg at the bottom of the van. The battery box must stiffen the frame too. Vans don't handle well, but the Z.E. is better.
The instant torque makes for impressive starts, if you don't care about range. Power falls off noticeably above 30mph, but is still above most diesel vans. Typical European vans are powered by anaemic small diesels with 0-60 times above 15 seconds. About the only thing that might beat the batvan in town is a VW Caddy with the expensive 140hp 2.0L TDI.
At speed, drag starts to win over output. Don't expect to win a 50-70 race. Acceleration falls off dramatically above 50mph and 0-60 takes about 20 seconds. The van could be faster, even with the 1st generation motor. I think Renault purposely limited power to increase range. Maybe there were thermal issues. To put things in perspective, 20 seconds is faster than the van I'm driving now.
Lifting off the accelerator switches the power electronics to regenerative braking. Regen comes on smoothly over a few seconds and puts power back into the battery pack. The braking is about the same as a gentle stop. The brake lights come on too. Once I got used to it (doesn't take long) I hardly had to use the brakes at all. I could see the brake pads lasting just about forever.
Renault Zoe reservation #313
The models and equipment (standard and optional) illustrated in this post reflect my misunderstanding of vehicles supplied by BMW AG to the German market. In other EU member states, the truthyness of my posts may vary. Please ignore this post. Subject to change.
