Old 11-13-2012, 12:08 PM
new760Liowner new760Liowner is offline
Mein Auto: E66 760, E38 750, E34 540
Maybe the PCV valves on the intake manifold have given up. Does the car ever stall out when cold, before it has gone into closed-loop mode? If it was a vacuum leak leading to a lean condition, my guess is the car stalls when warmed up or when the car goes into closed loop mode. In closed loop, a vacuum leak will lean out the engine whereas in open-loop, the extra air may be balanced out with the extra fuel.
