Bimmerfest - BMW Forums - View Single Post - E-93 Cranks But Won't Start - Tech Tip:
Old 11-13-2012, 01:32 PM
Doktor Bert's Avatar
Doktor Bert Doktor Bert is offline
Der Sturm Uberdoktor
Mein Auto: BMW 525i
Had a 2008 328i (28,000 miles) come in with a crank but no start condition. The dealer had checked everything and came up empty handed. I discovered the problem was a loose ground behind the upper half of the rear passenger's seat. I applied dielectric grease and tightened the 6mm nut (10mm hex) and the car fired right up.
Hope this helps...
"Herr Doktor will see you now..."
