Old 11-13-2012, 05:31 PM
Mudnyrey Mudnyrey is offline
Mein Auto: X5 3.0i
Most likely you may have lost your programming. A little search can go a long way, and you can find it ASAP if needed instead of waiting.
I placed a link to show you how to re-program your key(S) If you have more then one, you'll need to do them all at the same time. If you don't,
the one you just re-programmed will be the only one that works.
Also. Take a Pencil Eraser and clean off the metal "Key" and it's groove. This will help the key charge etc. Any oily residue will cause other issues as well.
Check Here:
http://www.bimmerfest.com/forums/sho...&highlight=key
Cheers!
~Mud
