Old 11-14-2012, 07:10 PM
bimmerfan52 bimmerfan52 is offline
Mein Auto: 545i
Originally Posted by Ralph III View Post
Thanks for the input.
What's the torgue with anti-seize? Otherwise, should I torgue a few pounds less/more when using such? BTW, I always check the gap of spark plugs for consistancy and accuracy.
Ralph
RE anti-seize I don't use it as BMW and Bosch recommend you don't. When I changed the factory plugs at 82K miles they came out easily.
However, there are many that swear by the use of anti-seize and I wouldn't argue with them if it works well for them.
If you use anti-seize, apply it sparingly. I would back off to 20 lb-ft to avoid over-torqueing.
