Replacing Door Panel Clips
I have a 328ic and need tp replace the door panel clips, but cannot see figure out how they were installed into the upholstery panel and if they can be changed. These are the white ones mounting on the black plastic housing. The only solution I can think or is to cut the housing open, change the clips, and cement the housing back together with Crazy Glue. Any other ideas would be appreciated. Thanks.
