Bimmerfest - BMW Forums - View Single Post - BMW 318ie key not turning in the barrel
Old 11-15-2012, 08:44 AM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x1,E30x1, F150
Yes. You need one of these and about a day for the work.
You can replace the "security screws" with regular metric round head socket cap screws. To remove the old security screws, either do the hammer and chisel routine from here: http://www.pelicanparts.com/bmw/tech...t/E36-Tilt.htm or slot the old screw heads with a Dremel cutoff disc and use an offset screwdriver to unscrew them. They are the worst part of the entire job. (yes, that says "tilt steering wheel retrofit", but the information you need is within that DIY article)
Quotes to live by:
Ken Kanne, Silverhill, AL, E36 Forum & New Member Intro Forum Mod-
Bimmerfest Misplaced-Posting Tow Truck
BMW-CCA #441426
1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette"
