Which side is the door sill out, i Might have one i can sell you that I bought as a pair? Its a quick removal, you will have to give a good pull to get it out. Utilize a pait can opener with some tape around it to avoid scratching your paint. Insert screw driver at one end and just lift. Don't pull at the entire piece because you have a wiring connector that attaches to the sill to illuminate it.
