Old 11-15-2012, 05:16 PM
Blacklane Blacklane is online now
Mein Auto: 1998 Z3 Roadster
That's interesting.
The switch almost has to be under the hand brake lever. You can easily access that area by removing the boot. To do that, you simply pull up and forward on the back of the boot. It's glued to a plastic frame that pops out. You shouldn't need to remove the boot, but if you do, there is a zip tie around the brake handle the holds the boot.
