Bimmerfest - BMW Forums - View Single Post - Coolant leak - Intake Manifold
Old 11-15-2012, 05:31 PM
luckydog's Avatar
luckydog luckydog is offline
Lucky to drive a BMW
Mein Auto: 2006 M5///
I have a good used multi port hose if you want. I have seen the results of small hose 15 split at the block connector and the owner ruined the engine driving on a overheat. I would add a a light silicone sealant on the old gaskets on intake to block.Maybe clean the idle control valve wile there.Final throttle linkage adjustment necessary.
