Old 11-16-2012, 07:13 AM
txag_530i's Avatar
txag_530i txag_530i is offline
Mein Auto: 2006 530i
It is very easy to do. You need a gallon of BMW coolant, an oil filter, oil, a 1/4"-drive E10 socket, u-joint and 8" long extension. You do not need to remove the inlet manifold. Wait to do the job at the next oil change.
Here is a DIY-
diy-do-yourself-14/oil-filter-housing-gaskets-replacement
I bought the socket a Snap-on for $12. You need to use a 1/4" drive socket and u-joint. Alternatively, you can use a 12-point Gearwrench 5/16" ratcheting wrench and a 12-point 5/16" socket.
