Bimmerfest - BMW Forums - View Single Post - tires
Thread: tires
Old 11-16-2012, 09:11 AM
DBU's Avatar
DBU DBU is offline
Mein Auto: Glacier Silver X4 M40i
Originally Posted by turnbowm View Post
Recently replaced the OEM tires (Goodyear Eagle RS-A) on my '05 530i with Bridgestone Potenza RE970AS Pole Position and I'm VERY happy with the change. As expected, the higher load & speed rating (98W vs 94V) resulting in a firmer ride with more awareness of road imperfections (potholes, etc.), but the improved handling & steering response was a worthwhile tradeoff. Very low tread noise was an added plus.
Be sure and checkout Tirerack.com. It's an excellent source of info on tire test results & reviews.
Looks like you are a few months ahead of me - thinking about copying what you just did. Did you change the tire size or stay with 225/50R17?
How many miles did the Goodyears give you? Mine just turned 60K and still OK. I rotated them exactly ONCE (front/back without changing sides).
Apologies to OP if you feel I hi-jacked your post. But I figured we both could learn more from this.
His: 2017 X4 M40i with all the options (except cold weather stuff - not needed in SoCal
Hers: 2007 X3 3.0Si
