Bimmerfest - BMW Forums - View Single Post - Thermostat Question
Old 11-16-2012, 12:25 PM
jburke4689 jburke4689 is offline
Mein Auto: 2007 335i
The thermostat is electronic. When it shorts I believe it fails to wide open so that you don't overheat. It will cause long warm ups and excessive emissions. That is why you have the SES light on. It will need to be replaced. The thermostat runs about $100. An Indy would probably charge around $250 to install it. Belt and tensioner are recommended for replacement together about every 4 years. The probably last twice that long. I wouldn't worry about the tensioner until it starts making noise.
