Old 11-16-2012, 02:22 PM
mossman35 mossman35 is offline
Mein Auto: 2016 340 Xdrive Msport
Originally Posted by ///M-ratedE90 View Post
The wheels are tilted inwards to help with handling (negative camber), so the inside edges wear faster. The dealer is not bull-sh****g you, so you should buy this, he is looking after you. Turn the wheels to full lock and check this out for yourself.
Also rear tires wear faster than fronts as they put the power down for the car (in RWD). Even with X-drive, the rear tires carry more load due to weight transfer during acceleration. It is not unusual for rear tires to wear significantly faster than fronts.
I can confirm that on my Xdrive my winter tires (non staggered) are more worn in the rear than the fronts. I swapped front to back this year. I doubt I get a 3rd winter out of these tires. I don't drive slow around turns snow tires or not. They are wearing evenly across though.
